I DON’T KNOW WHAT IS HAPPENING MY PAGE GOT CRAZY AND SAYS THAT IT MISSES MEMORY
I already moved the memory limit from 40 to 128 and also to 256 and it still doesn’t work
It looks that you mange top solved the problem -> https://i.imgur.com/ktZkQZ0.png normal the memory need to be reflected in theme panel system -> https://i.imgur.com/h0DwTy2.png when you are using some extra plugins is possible to need some more memory, what you can do then is to double the memory.
If there is still a problem, please let me know!
