Dear Sir/Madam
I am writing to seek your assistance. I brought the beautiful newspaper theme on Monday and installed it on my website http://www.relationshiptips4u.com I have a problem that aroused. The content of the articles are showing up, but the images are not showing.
I am writing to seek your assistance in rectifying this situation. Thank you very much for your assistance
David Small
Usually the cause for any image problem that happens is the result of a plugin. A possible solution and a first step is to deactivate all the plugins as a test, except the ones provided in the theme. Then clear any caching installed on your website and check if the issue is resolved. If the images are displaying properly, that means a plugin is to blame. You could enable them one at a time to hopefully identify it.
Some plugins interfere with the theme functionality, and the first to break is the lazyload image feature. You can try to disable this in the theme panel and see if it has any effect – https://www.screencast.com/t/hlsWRcWKaWcz
But it would be better to identify the cause.
