Help with NewsTicker
Please take a look at my website(http://www.newsmug.in/).I am currently using my native language in this website.If you view the contents of Newsticker,few characters are being cut off.How do I increase the length of the Newsticker block so that all the contents fit in inside the block
Please take a look at my screenshot here
http://www.screencast.com/t/y7oyxYTB
Thanks,
Anand
Hi @Andy,
You can increase the length of the Newsticker block within Theme panel like that: http://screencast.com/t/7f8xTtDJ7NJ
http://screencast.com/t/n0Dk2OZBn.
Hi Catalin,
I increased the length of the Newsticker block in theme panel but still it was of no use.Please help me with this.Please take a look at my screenshot
http://www.screencast.com/t/9Y19jTxK
Thanks,
Anand
Hi Andy,
Your problem persist because you are using a quite large font size for Newsticker and your native language do not support this and some letters are cut. I recommend you adjust this value in Theme panel like this: http://screencast.com/t/wcrPHY7w
Also your problem should be solved. Let us know how it goes!
  • This reply was modified 11 years by Catalin.
