Hi guys,
We have a special circumstance where we need to use a plugin but need your help to properly integrate it following the plugin author documentation:
We just need your help following their function example for theme TwentySeventeen to the Newsmag theme:
if ( ! function_exists( 'twentyseventeen_posted_on' ) ) :
* Prints HTML with meta information for the current post-date/time and author. Supports Molongui Authorship plugin.
function twentyseventeen_posted_on()
// Integrate Molongui Authorship with TwentySeventeen by replacing twentyseventeen_posted_on() with this function
if ( function_exists( 'get_the_molongui_author_posts_link' ) )
$byline = get_the_molongui_author_posts_link();
else
// Get the author name; wrap it in a link.
$byline = sprintf(
_x( 'by %s', 'post author', 'twentyseventeen' ),
'<span class="author vcard">' . get_the_author() . '</span>' );
// Finally, let's write all of this to the page.
echo '<span class="posted-on">' . twentyseventeen_time_link() . '</span><span class="byline"> ' . $byline . '</span>';
endif;
Thank you so much. Your help will be greatly appreciated!
Best,
Hansel
Hi Hansel,
Unfortunately, we cannot provide any support for the integration of any untested plugin, sorry! Notice that’s not a simple task and if you are not aware of the steps which are needed to take in this case, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
