My Advertising widget has disappeared from the sidebar and I need help with it.
Please view here:
https://seanews.co.uk/shipping-news/development-of-ai-as-a-tool-gathering-pace/
The advertising bar should be like the homepage:
Thank you for any assistance provided.
Ok, first I have a question, for your articles you used a standard template or a cloud template?
1. If is a standard template, then the sidebar widget is no longer apply because: no longer exists, or the widget sidebar no longer has the elements to it, in this situation you need to go to appearance > widgets and add back the widgets from inactive widgets to newspaper default sidebar (I believe this is the one that has been used).
2. If it was a single post template from cloud, then you just need to assign it as global and the problem will be resolved – https://forum.tagdiv.com/single-post-shortcodes/
