First, once again (I wrote a comment on themeforest) I want to say how great was this last update! Thanks for that.
We have a cooking site, so we are thinking of using recipe demo as our look. I did some “research” 🙂 and found that numbers in single post which are used as step by step instructions for preparing meal are dropcap circles. I found in theme panel, in custom body class this custom code: td-recipes. I thought that it is why dropcaps show differently in recipe theme, then in base theme. About that, I have just one complain: if text in one step has just one line, next step does not look good…
Second, I would like to ask is there simple way of showing prepare time, cooking time and ready in, than using code in every post:
<div class=”td-recipe-time”>
<div class=”td-recipe-info”>Vreme pripreme: 30 min</div>
<div class=”td-recipe-info”>PeÄŤenje: 20-30 min</div>
<div class=”td-recipe-info”>Spremno za: 1 h</div>
<div class=”clearfix”></div>
</div>
It is great that now we have that option, but some kind of simple shortcode button for that would be nice, because I believe not everyone understands how this works.
But, if there only is another way, please excuse me for writing here, and for not looking carefuly enough 🙂
Thanks in advance for help!
Hello SanjaKokica,
First of all, I want to thank you for your kind words and I feel glad that you are excited by our new theme product.
So, as you can see, all our demos has their own custom made style and if you are not using that demo, you will have to implement yourself all the design elements that you like. Please notice that each demo has their own style.css from the demo folder, like this -> http://screencast.com/t/4lbEzaD1Jc Please notice that these classes are custom made and you cannot use them for your backend as shortcode if it were not loaded. Please check the demo_style and try to implement this style as you wish.
Also, please notice that if you need more customization in this regard and you are not aware of the steps which are needed to take in this case, please consider hiring a freelancer/developer to help you because we cannot provide customization services at the moment, sorry!
Hi, thanks for quick answer 🙂 I am not shore if we understood each other 🙂 We do not need more customization, we are going to install recipe demo (just preparing for the right moment, because of visitors on the site and changes that have to be done). We already tried demo on our test site and are very pleased with it. I was just asking did I get it right, that, for Prepare time, Cook time and Ready in to be shown as in your demo posts, I have to use that code? (I may confused you, because it was translated to Serbian…) It is OK if there is not, just wanted to be shore how you did it.
Hello SanjaKokica,
Yes, if you want to achieve the same style for your content, you will have to use these custom classes to bring this style.
If is not what you mean, please provide more details about what you want to achieve with some useful screenshots, so I will be able to provide a more accurate response.
Yes, that is what I was asking 🙂 Thanks for the answer 🙂
