Help with removing unauthorized domain and reset assignment timer
I have a Newspaper theme license and I noticed an unknown domain edohard.com is active on it. I did not authorize this activation.
Because of this, both my license slots are occupied and I cannot assign my license to a new domain. The system says I can only unassign after May 9th 2026, which is too long to wait.
Could a moderator or support member help remove the unauthorized domain from my license and reset the assignment timer?
I have also sent an email to contact@tagdiv.com regarding this issue.
Thank you
We’ll check it via email, just make sure that you also include the license key so we can make the request on the key.
The issue has been solved. Thank you
I’m glad!
