In the side bar of the following page(http://www.anandambi.com/myblog/category/abs) there is a section called “Hot News”. In that section I want to add only 4 to 5 post from different categories which I like.How would I do that
Hello Andi,
When you create your sidebar (or edit the existing one) you can edit the block settings: http://screencast.com/t/UVnEfOftp0Ds
You can filter categories by ID. You can see the category id here: http://screencast.com/t/MqtXVVBg
Hi again,
Unfortunately, there is no option to pick the posts to be displayed but there is a workaround: You can filter your block by tags (type in your tag/tags here): http://screencast.com/t/7tpDXwFF and just tag your favorite posts with that specific tag: http://screencast.com/t/xLi94lY75
Thank You!
