Help with styling Megamenu
Hello, I’d like the megamenu not to show the text list on category posts under the images, can’t find an option to get rid of those, so I guess I’m having to code a bit. can you suggest me where to look for to change this?
I’m attaching a jpg for clear reference: Thank you!jpg
That would mean the mega-menu is not created properly
https://forum.tagdiv.com/mega-menu/
The menu item you want to make a mega-menu should not have any sub-menus. This is a common mistake when creating a mega-menu
https://forum.tagdiv.com/topic/hopefully-last-bit-of-help-slight-issue-with-the-mega-menu/
We will include a video in the tutorial and hopefully present the creation of such a menu in more detail. Let me know if you have more questions.
