Help with the curve border of Posts
If you see properly, it’s not an actual curve, there is the grey background behind every post. Please help
Hi iamratnesh, this is because you are using for all image another background image, this one -> https://i.imgur.com/2rcdbTo.png -> https://i.imgur.com/fjTvOYm.png
What you can do is to find from where is coming that background image and remove it or you can use a css for the flex block 1 -> https://i.imgur.com/vELTd0I.png
.td_flex_block_1 .td_module_wrap .td-image-wrap:before {
border-radius: 30px;
Set the code in the theme panel > custom code> custom css.
I hope this will help you!
