Help with Video Posts
Please take a look at this post(http://www.newsmug.in/special-page/photo-video-gallery/inspirational-video).I have used Post style 11 template. However I dont want the Ads to be displayed in mobile specifically for this template.How would I do that
Also please take a look at this post(http://www.newsmug.in/sports/higlights).I have used Post style 10 template.I want the title to be displayed above the Video right now the title is displayed below the video.Please help with this
In order to remove the ad on mobile phone you can add this custom css in the theme panel:
@media (max-width: 1018px) and (min-width: 768px){
.td-a-rec-id-post_style_11 {
    display:none;}}
For the second part you need to edit the core files of the theme. This requires a bit of code knowledge.
You cannot simply move the title from the bottom to the top.
You can copy the header from here: http://screencast.com/t/iKprjF3j
And add it to single_template_10.php You need to change the class to the title in order to target it with CSS:
http://screencast.com/t/L2FP8KZLth
Then you will have 2 post titles. One above and one below the video. Now you can use css to position the title above and hide the one below:
.td-post-title_custom{
  margin-left: auto;
  margin-right: auto;
  width: 400px;
.single_template_10 .td-post-title{
display:none;
This will require a bit more tweaking, but this should set you on the right path.
