HI, how to enable RTL for a post ?
Unfortunately our theme do not have this option, to achieve this you need to use a custom css, also is possible to be some elements that need to be adjusted.
.single {
direction: rtl;
The code need to be set in theme panel> custom code> custom css.
Sorry but our themes are not compatible with the RTL direction. If you need a RTL theme, you will have to choose a different theme that can provide this functionality. There are elements that can be fixed, but there are still other elements that will not work properly.
We will be able to provide a refund if you make a request here:https://themeforest.net/refund_requests/new
