Hide meta info specific block
is it possibile to hide meta info just for specific block? I want to hide the review stars just from that block (see attached screenshot)
https://ibb.co/0rJPBvh
For example, if that block is a flex blocks created with TagDiv Composer, then you should be able to hide the review stars from the element’s settings.
