Hide same posts from related article block
When i click on one of my posts, the same post is also showing in the related article block, right under that same post. This means double. This is not a good user experience. This is probably because of the use of multiple categories.
How can i make sure the particular post doenst show up again in the related article block?
  • This topic was modified 9 years by Eric V.
Hello stinus,
Please provide more useful details about your problem. You should provide me your link and some screenshots to show me the problem.
Hey Catalin,
I think it was a strange glitch. When i was in a post, i did see that same post in the related article block right under it. I think the issue resolved itself. I have no idea. You?
Please show me exactly the block which you are referring to.
