Hide searchbar problem
Hi, I followed a previous post on hiding the search bar using CSS, but I have found that even with hiding it, it flashes on the menu when I click on other pages. What can I do to fix this?
Here is the site: dev.elevate.study
Try entering the code that you used – https://www.screencast.com/t/QEOrY1nrA506 directly in the theme’s style.css file. This is located in the main theme folder. You can open it with a text editor and place the code at the end
– https://www.screencast.com/t/ajf51cvgZ6s
