Since the last update, there’s a new column in the admin dashboard for posts showing total view counts. Is it possible to hide this, for everyone, by default ? Example: https://i.stack.imgur.com/BLXVW.png
You can try a code like this in the theme’s functions file
– https://www.screencast.com/t/qtET7iBnp
It should remove the Views field from the screen options, and the views column
– https://www.screencast.com/t/HMxnX6cJD1
– https://www.screencast.com/t/ZR1btZl2vqj
function my_columns_filter( $columns ) {
unset($columns['td_post_views']);
return $columns;
add_filter( 'manage_edit-post_columns', 'my_columns_filter',10, 1 );
