I set the home of my all website with BIG SLIDE. The BIG SLIDE did not activate the autoplay and also makes me all the news. How to enable the autoplay and how to filter the news by categories?
I thought that with all of these updates would have put the option directly in the theme panel.
Do you use that template with BG that add the Big slider automatic? or you have added the Big slider from Visual composer, because there you have all settings.
If you use the Big slider from template you have to edit it from files like here: http://screencast.com/t/10JccmfWOv
I used those option:
'sort' => '' – this is for latest(default – no value)
'autoplay' => 1 – autoplay at 1 second
'category_ids' => '219, 311' – filter by multiple categories ID
Hope this help!
Thanks for your message!
