Home Page problem
I had Newspaper in my blog before, and I just bought Newsmag
I followed the doc step by step
( Visual Composer was installed so it does not ask me install again)
Here is the result
http://www.screencast.com/t/OHyAILzq2t
Do I miss something?
Please make sure you have the Visual Composer plugin is activated.
Yes, it’s version 4.3.4 and it’s actived
I am having the same problem (please see my thread from this morning)
If Visual Composer is activated from an other theme may this cause this issue.
Try delete Visual Composer plugin then active WP temporary theme then back try to active Newsmag and of course the fresh Visual Composer plugin right after.
I hope this may help you. Good luck.
  • This reply was modified 11 years by Gregory.
I have the same problem.
I’ve tried to delete Visual Composer and install it again and the problem doesn’t disappear.
Here is the screenshot of my admin panel:
http://s22.postimg.org/a2h531vxd/bug.png
and here is the main page:
http://s30.postimg.org/8q3e9pt4h/bug1.png
Please help us to solve this problem.
I’ve forgot to point out, that I use WordPress 4.0.1 and Visual Composer 4.3.4.
The setup of wordpress is clean, I just installed your theme with necessary plugins.
Have anyone solved this problem?
I’ve tried to install wordpress at localhost and install your theme…there is the same problem.
Yes, sorry for the delay and sorry for the inconvenience as apparently we haven’t made the changes need to the Visual Composer plugin. We will release a patch with a fix this week. This happens when you use the custom templates added to the Visual Composer so you need to build you own page and add elements to the page.
Could you tell me, when will you release this patch and how can we get it?
Unfortunately I can’t give you and exact answer, hopefully on Friday or at the latest at the start of next week as we have a lot of work, short time and few resources. You will receive a notification from themeforest when an update will be available.
Hope you understand! Thanks for the message!
Hi has the patch been done? Still cant edit the homepage.
Aldo
Yes, we have released an update, you can find the change-log her: http://themeforest.net/item/newsmag-news-magazine-newspaper/9512331 at the bottom of the page. Please make sure you download the latest version then check again and let us know if you still have this issues.
I installed the update, deleted and reinstalled the Visual Compose plugin, the homepage still wont save, an updating circle just keep on turning. when I add a template or element it is there but when I update it is gone.
Please make sure that you try this without any plugins active just to make sure that this isn’t caused by a plugin. If you still get this error please give us wp-access and send your login details at contact@tagdiv.com including a link to this topic or specify your issue in details.
Viewing 16 posts - 1 through 16 (of 16 total)
