After changing the theme colors of megamenu option in the theme panel, and do save settings, all pages of the site now show up strange code like the following excerpt at the top of the pages. How can we revert this? we cannot access this anywhere. Please help! site is:
; } .td-theme-wrap .td_mod_mega_menu:hover .entry-title a, .td-theme-wrap .sf-menu .td_mega_menu_sub_cats .cur-sub-cat { color: #636363; } .td-theme-wrap .sf-menu .td-mega-menu .td-post-category:hover, .td-theme-wrap .td-mega-menu .td-next-prev-wrap a:hover { background-color: #636363; } .td-theme-wrap .td-mega-menu .td-next-prev-wrap a:hover { border-color: #636363; } .td-theme-wrap #td-header-search, .td-theme-wrap .header-search-wrap .td-aj-search-results { border-color: #ed5f48 !important; } .td-theme-wrap .td-aj-search-results .td-module-title a, .td-theme-wrap #td-header-search, .td-theme-wrap .header-search-wrap .result-msg a { color: #000000; } .td-theme-wrap .td-aj-search-results .td-post-date { color: #ed5f48; } .td-theme-wrap .td-aj-search-results .td_module_wrap:hover .entry-title a, .td-theme-wrap .header-search-wrap .result-msg a:hover { color: #4db2ec; } .td-theme-wrap .header-search-wrap .td-drop-down-search .btn { background-color: #ed5f48; } .td-theme-wrap .header-search-wrap .td-drop-down-search .btn:hover, .td-theme-wrap .td-aj-search-results .td_module_wrap:hover .entry-title a, .td-theme-wrap .header-search-wrap .result-msg a:hover { color: #ed5f48 !important; } .td-banner-wrap-full, .td-header-style-11 .td-logo-wrap-full { background-color: #ffffff; } .td-header-style-11 .td-logo-wrap-full { border-bottom: 0; } @media (min-width: 1019px) { .td-header-style-2 .td-header-sp-recs, .td-header-style-5 .td-a-rec-id-header > div, .td-header-style-5 .td-g-rec-id-header > .adsbygoogle, .td-header-style-6 .td-a-rec-id-header > div, .td-header-style-6 .td-g-rec-id-header > .adsbygoogle, .td-header-style-7 .td-a-rec-id-header > div, .td-header-style-7 .td-g-rec-id-header > .adsbygoogle, .td-header-style-8 .td-a-rec-id-header > div, .td-header-style-8 .td-g-rec-id-header > .adsbygoogle, .td-header-style-12 .td-a-rec-id-header > div, .td-header-style-12 .td-g-rec-id-header > .adsbygoogle { margin-bottom: 24px !important; } } @media (min-width: 768px) and (max-width: 1018px) { .td-header-style-2 .td-header-sp-recs, .td-header-style-5 .td-a-rec-id-header > div, .td-header-style-5 .td-g-rec-id-header > .adsbygoogle, .td-header-style-6 .td-a-rec-id-header >
This topic was modified 5 years by
jose.sa@casadoprofessor.pt.
You will have to first start looking for a plugin conflict.
Please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
If this problem is not solved after that, then we need to take a look and see what happened there.
– admin url and credentials
– cPanel url and credentials
Our team will take a look!
