Home problem for Mobile and modules, help please
His, i’m having problems with the modules for my home page, in regards to Desktop to Mobile.
Please, see the attachment photo of Home in Mobile, and the titles are too big for photos.
How can I make the title appear below the photo, for example, and not on top of it?
Please help. Although it is a guide.
Image 1 – Home Desktop (Correct): http://lasopapa.com/wp-content/uploads/2018/01/Captura1.jpg
Image 2 – Home Mobile (NO … wrong): http://lasopapa.com/wp-content/uploads/2018/01/Captura2.jpg
Hello Mariano Jonte,
Unfortunately, I cannot access your website. Please check it and provide it again so I can inspect it closer and also, so I will be able to provide a more accurate response. Also, I need some useful screenshots so I can see the problem.
Thank you Catalin, my site is http://www.lasopapa.com
Link: http://www.lasopapa.com
I’m sure there’s access, maybe at the time you checked in there was a problem.
Images (again):
1
2
Thank you and happy new year
Sorry, I cannot access your website because I guess that you have some restrictions to your country. Plese, get out there so I can access it, please!
I have already uploaded the images to an external and free server. To be able to visualize what I say. In pictures.
There is a problem, especially with the ENTRY titles. In desktop it looks very good, but in MOBILE, the text covers almost the entire image. Please see the screenshots.
BIG GRID 2:
https://image.ibb.co/nDy06b/Big_Grid2_Desktop.jpg
https://ibb.co/f1s4XG
Desktop: OK.
In MOBILE… wrong:
https://image.ibb.co/ji5PXG/Big_Grid2_Mobile.jpg
https://ibb.co/fjtYRb
As an example, in the image, below, you can see how the title would look good on mobile. But it does not adapt the Big Grid 2 … since it does not have this configuration option.
Please, tell me how I can do, since all the Big Grid have the title on the photo for MOBILE. That’s why I wanted to use the BLOCKS, but there’s no possibility that they cover 100% of the desktop width.
In short, a big problem. Please help.
I guess that you are referring to the different element. The title will cover the images only for Big Grid and if you want the title posts to be under the images, you should use the Blocks. Check our demo tutorial and check the results.
If is not what you mean, please provide more details about what you want to achieve.
Hello, yes, it is that I want that in MOBILE the title does not cover so much the images. But it turns out that if I use BLOCKS, they do not look good desktop, so I have my other post relating to the subject.
That’s my problem, if I use BIG GRID; it looks good on Desktop, but bad on mobile. And if I use BLOCK, it looks bad on desktop but something better on Mobile.
Hello Jonte,
This is the preview of our demo on mobile devices, like this -> https://www.screencast.com/t/clbzaiypkPml Do you want to move the post title from Big Grid under to the featured image for Mobile Devices to look like on the blocks? Sorry, I guess that you need more additional customizations to change the default theme’s style and also, notice that we cannot do this because we cannot provide custom work at the moment, sorry!
Thanks for your reply, I understand… but then I would like to use BLOCK in both, just as I inform in my other post, the BLOCK is not working well on my site, so I opened the other post. If the block is displayed well on my site, I can use it for both desktop and mobile.
Hello Jonte,
Unfortunately, your website it seems to works too slowly and I cannot investigate it your blocks, sorry! Please try to make a new clean install from scratch via FTP way to another sub-domain and install only the plugins that come bundled with the theme core files and rule out any conflicting plugins. If you are using some untested plugins, you have to disable all of them because these might interact with the theme core files and causes a lot of unknown issues. Best make a new clean install from scratch with the latest version of the theme and check the results.
