Home Url : Site Url problem
I just update the themes of my blog and the errors appears.
https://snag.gy/D5yAvi.jpg
1. Error Images and have no Display – https://snag.gy/frygm4.jpg
2. Green Padlock not working – https://snag.gy/YPB1Dc.jpg
Iam not good in coding, What should i do in this issue.
Looking for help, thanks.
  • This topic was modified 7 years by purlp.
Updating the theme won’t change the home or site URL in the WordPress settings. These are defined here
https://codex.wordpress.org/Settings_General_Screen
If you did not make any changes there, maybe your hosting made them or can check what happened.
Please contact them and ask about this. This could explain the other issues you are having with the media library and SSL.
Hi Simion I read your reply but it’s already late my site is already working, the solution that you give is same what i do.
You must update the WP Home URL (WordPress Address (URL)) with the https:// version. This will surely solve the gallery issue.
To fix green lock issue, open theme panel, and check if the side logo, favicon, background URL has https in their URL REFER: http://prntscr.com/ljqsqt
Note: Things may break If you are using CloudFlare Free SSL on your website. You must configure it very carefully.
Hope this will help, thank you for your understanding.
