Homepage Big Grid problem
Hi, on my homepage my first grid at the top is the “Big grid” which has the bigger picture on the left, and four little picture grids on the right. The four little picture grids on the right are blank and they are not filling in with pictures. For the life of me I cannot figure out how to fix it. It is working fine on all my category pages, but not on the homepage. I had someone set the theme layout up for me and they had some grid title tags that I did not want, so I edited some of this type of looking code off the front page on the backend editor, since that was the only way I found to get rid of the tag things I did not want there. Here is a snippet of the code that I altered [vc_row][vc_column][td_block_trending_now] In this example if I did not like the word “trending now” being above my grid block, I took the whole line of shortcode out. Not sure if this is why. But right now, I just want the top big grid to work properly with what I have on the homepage. Here is my site if someone can take a look http://www.viralbuzzme.com you will see all the category pages the top big grid is working the way it should by filling in all the picture grids, but only the homepage is not working that way. Please help!!
Thanks,
Steve Richard
I’ve checked your site and noticed that the four small modules on the left of big grid are empty, there are no posts to be displayed: http://screencast.com/t/9xLQu6zE5xO Check if you have enough posts according with the grid’s settings from Visual Composer: http://screencast.com/t/LWIN8ZUSX I mean if you have at least 5 posts in the category selected, or in others filters that you have set. Also clear all caches and test again.
Let me know how it goes.
