Homepage blocks Visual composer help
Even if I set visual composer blocks side by side they don’t show up side by side, they show up below each other.
No matter what type of blocks I use they show up below each other rather than side by side.
Showing my issue with Block21 + Categories
Visual composer settings I use:
https://www.dropbox.com/s/az4i2v81idsuvsq/Issue1.PNG?dl=0
How it looks:
https://www.dropbox.com/s/7ms9kdkea0s0gv0/Issue2.PNG?dl=0
How I want it to look: Side by side blocks
https://www.dropbox.com/s/zrh2ee4dapt2v92/What%20I%20want.PNG?dl=0
Please provide other screenshots as the ones you posted are not working. Also provide a link to your website so we can inspect it for errors.
I found the problem It Was W3 Total Cache minify settings causing it.
