Hi, I imported the Week Pro demo and I’m customizing the homepage. The content area is narrower than the original demo — the rows don’t stretch to match the full header width (from MENU to SUBSCRIBE button). I’ve set Page Layout Size to 1400px in Theme Panel, and Row Stretch to “Stretch row and 1400px content” on each row, but the content width doesn’t change. What setting am I missing to match the Week Pro demo layout width? Thank you.
To set a page or template to full width or adjust its width, you’ll need to edit it using tagDiv Composer: https://i.imgur.com/i5IUJ9E.jpg
Add or select the row, then go to the General tab and look for the Stretch option. From there, you can adjust it based on your needs: https://i.imgur.com/WKYebPX.jpg – https://i.imgur.com/TO1BZ3M.png – https://i.imgur.com/Yq8UCv3.jpg
If you want to make the entire layout full-width, you should also check the Theme Panel settings. Make sure there is no background color or image set, as this will force the website into a boxed layout. Ensure this option is disabled: https://www.screencast.com/t/ejiNPCBF
