You might post the issue on the Yoast SEO support page on WordPress.org. If you have the “premium” version of plugin, you can ask them to check your site for you.
TagDiv does not manage the Yoast SEO plugin.
I’m using it on ALL our sites with no issues, with various themes.
Also note that technically there is no “index.xyz” file just your website:
So, on the “page” you create to develop your home page be sure to put in all the info for Yoast to optimize it. It should work.
If you have a problem, it might be another plugin, or caching.
Try editing the Yoast settings with ONLY the Visual Composer plugin running, and Yoast SEO, and ALL other plugins OFF.
