I installed the church theme and edited the way I want it to be. But, I can not remove the latest articles sections which came by default. It is not editable. Could you help me please?
When you edit simply (not with TagDiv Composer) a page, you can set up this setting: https://www.screencast.com/t/QUEYtO2p5XQ (default template).
After this setting on that page, the Latest Articles will disappear, but you can add a Post Loop with TagDiv Composer and modify how you want.
Hope that helps you!
