I am trying to limit the number of posts on my homepage.
I adjust the number of Posts per page in the homepage loop filter but it doesn’t change.
Any help would be greatly appreciated.
thanks
hi,
http://screencast.com/t/TgZZp2ClSW , http://screencast.com/t/0nuijt3xxLOm
works perfectly for me. please try to disable all the plugins, there may be conflicts.
Thanks for you message.
Radu A.
Hi Radu,
I have disabled all plugins through ftp by renaming the plugins folder.
The Homepage Loops Filter Posts per page is set to 5
The Setting > Reading – “Blog pages show at most” is also set to 5
As you can see at http://betheline.com/dev/ there are more than 5 posts showing.
Any help is greatly appreciated
