Homepage Question (Probably Simple Solution)
I created a “Home” page, but this appears to be different than the initial page I am navigated to when entering my website. I would like the “Home” page to actually just be a button the user can click to return to the original homepage when entering the website. Is there a way for me to do that?
Is there a way to tagdiv compose the initial homepage as well?
Yes, you can build it with the TagDiv Composer. There you can delete the elements, add new ones, add the element called ” button ” where you can add a link. For more information about TagDiv Composer, please check our documentation here: https://forum.tagdiv.com/tagdiv-composer-tutorial/
Hope that helps you!
