I have that problem with stupid Internet Explorer 11 on Win7/64 … have to switch over to Chrome and stuff all works.
Might not be the cause of your issue, but it does work. It’s always one of these
1) stupid Internet Explorer 😉
2) caching issue
3) bad plugin conflicting with Visual Composer
It’s always one of those. Trick is figuring out which! 🙂
Note: even with Chrome I did recently have issue where going to save a new row or something didn’t stick and realized if I did anything notable I needed to press the “save” on right side to make sure that step “stuck” — then went to next thing to mess with. Pressing “Save” seemed to clear it from it’s “lost in thought” moment.
simchris.
Yeah.. there is some plugin we had, too, where it had simply named CSS, vs “unique” named CSS, and it conflicted with the VC plugin. SO, two different things were loading same time.
This is why “good” plugins will NOT load jquery AGAIN if already loaded by theme, and will ONLY use custom variables like “td_bunny-font” vs “bunny-font” 🙂
Always a fun time!!
