Homepage slider images don't render correctly on first load
Hello! My problem today is that often my homepage, which has the normal slider in the top & first 2/3 of the page, renders all the images from top to bottom, rather than as a slider. I limit the slider to 4 articles at a time, so those 4 featured images often render below each other, as in my example photo here. That photo shows the slider images rendering on top of each other, and the ones below the main slider space go under the blocks and content below, and it makes it look quite ugly and messy. Any idea what’s up?
Christian
I suspect that this is happening due to the speed booster plugin as a result of moving the js/css to the footer and a long server response time.
I suggest you deactivate all plugins though and check this without and plugins then activate them one by one to make sure that this is it, also make sure you empty cache and purge files.
You can also try to enable page cache and check if this still happens.
