hook to load firstly featured image posts
Hi all!
is there a way (hook, trick, whatever…in wp or in the template) to routing a request to load in each view or template (mainpage, categories, etc.) firstly posts with featured image related and secondly posts with the default “noimage”?
In my instance i’ve imported quiet 30k posts from an xml archive of cultural heritage but a lot of them don’t have a featured image loaded yet.
http://www.catalogobresciamusei.it
Thank you all. Great work guys!
The theme does not have an option to display first the post with featured image and only at the end the ones without the featured image. To achieve that is required a new filter in theme options and also must be modified the query which display the posts.
This is a very complex task which require many customizations in order to be achieved. Unfortunately the time does not allow us to offer custom services at the moment so so if you still need guidance on this or you’re not aware of the steps you need to take in this regard please consider hiring a developer or a freelancer to do this for you.
