Hello, I have installed the WooCommerce plugin in the Newspaper theme and I want to customize the thank you page by adding a summary of the order that does not show by default, when using the payment method of bank check, but there is no way to make the hooks work, the 2 redirect me to the cart page with a message from your cart is empty. (the order is successful).
I have tried a specific hook for the payment gateway with id ‘cheque’:
function woocommerce_thankyou_cheque_payment ($ order_id) {
echo '<p> Thank you for your purchase. Payment will be made in cash at the establishment </ p> ';
return '<h1> THANK YOU. </ h1>';
add_action('woocommerce_thankyou_cheque', 'woocommerce_thankyou_cheque_payment', 10, 1);
And this hook is general, to check if something worked:
function redirigir_paginaGracias_metodoPago ($ order_id) {
$ order = new WC_Order ($ order_id);
$ url = get_home_url (null, 'thanks-pagometalico');
// if ($ order-> status! = 'failed') {wp_redirect ($ url); exit; }
add_action('woocommerce_thankyou', 'redirect_paginaGracias_metodoPago', 10, 1);
Maybe I have to see something with the filters? How can i fix this?
You could edit the Woocommerce thank you template page itself, and enter your content there for example
– https://www.screencast.com/t/81wVKG4MS
Or maybe try something like this and create your own custom thank you page
– https://www.woobeginner.com/woocommerce-thank-you-page/
– https://www.tychesoftwares.com/how-to-customize-the-woocommerce-thank-you-page/
