Horizontal (Landscape) Mobile view Issue
Hello, I’ve recently changed my mobile phone to a 6,67″ screen one. At that moment, I’ve noticed that responsive view when I put my mobile in horizontal/landscape position is the same as I have in a common PC. I mean, you see the landscape mobile version when you should see the landscape one. I’m not using an independent mobile theme, it just the standard one. As I said, I’ve noticed it when changing to a greater screen mobile, in my old one I saw/see the correct landscape.
¿Is there any way to solve this and having the correct mobile landscape view up of certain screen size/horizontal pixel resolution? I’ve tested in Firefox developer options and the landscape change when horizontal is greater than 770px.
Many thanks, Raul.
The problem arises because the resolution on the new phone is higher than the default set for landscape mode
So then, is there any chance to increase this default landscape pixel size to mobile view? I just wanted to test if it is possible.
Many thanks
Unfortunately, this can be done only in the theme files, but there are more places, and I don’t know if it will work.
