Hot to customize ionMag post templates inside child theme
Hi, I’m still using the old theme ionMag and I need to add some script directly to the post template.
I create folder parts/single/ where I upload two files
loop-single-rd9.php
single_template_rd_9.php
I’ve made the change and nothing. Doesn’t work at all.
Hi sporten,
The ionMag is not covered by the support, we can provide support only Newsmag and Newspaper theme.
Ok no problem
