Hello
My front page is creating too many internal links. How can I nofollow the titles, categories and experts on the front page posts. I cannot seem to find an options to do this so I can reduce the amount of internal following on the front page.
Hello @mgiannelis!
Unfortunately, if you mean blocks, then there is no option for that. We have this option for the other elements like social icons,etc.
Yes it seems like this is not possible.
I think you need to consider this in your next up date. This is a massive SEO restriction and big problem This in itself is making the theme very non seo friendly. Allowing over 400 internal links that are ” FOLLOW” on the front page is a very very bad thing.
All you need to do is add an option for ” BLOCKS” to be follow or nofollow
This reply was modified 4 years by
mgiannelis.
The theme is SEO flawed bigtime
My domain is Ranked No1 and has big page authority on the front page. The current live site shows only 5 internal links. Now that I have my staging site and out your theme on it, this has created over 400 internal links. This is a massive problem. If I put this live on my main domain with this new theme on top the “Page Authority” is going to split off 400 ways. The theme is going itself is going to kill my landing page “Page Authority”
Google also only recommends a MAX of 100 internal links per page.
So if I live my site now with your theme on top. I am going to lose my No1 page 1 rankings
I am ranked No.1 in Australia for the search term ” TECH NEWS” If I use this theme now my rankings are going to TANK.
You need to fix this issue. The block are a bad idea. You need to lift them off the page or make an easy way to “NOFOLLOW” whole blocks.
I have just discovered this big seo issue. It is so bad now after three weeks of planning this theme and getting it right. I now have to abandon the whole project. The theme itself due to the SEO issues will kill my news and media business
You need to add the option to make “Blocks” NOFOLLOW.
I have seen so many people using this theme for news sites. I think they have no idea there front pages are bleeding off authority very badly by splitting it hundreds of ways
Hello @mgiannelis!
I understand your issue, and I will add this feature on our improvement list.
Thank you for your feedback and request!
