Hover over submenu in header not showing custom post types
Hi, my website is required to have custom post types, and they work perfectly. But on submenu in header menu when I hover over subcategory it only shows default post types. I think that the problem is that posts(their thumbnails/links) are loaded using ajax, and I haven’t declared to show custom post types. How should I fix it?
If I understand correctly you want to show the custom post type in mega menu, unfortunately this is not possible for the moment, sorry!
