How add comment box in TD Composer?
How to enable comments on selecteds where is build with TD composer?
many thanks
I don’t think I understand exactly what you mean. Comments can be enabled for pages in the theme panel, if that is what you want
– https://www.screencast.com/t/nQWzAndriqIy
Disable that setting and make sure the comments are enabled in the page settings as well
– https://www.screencast.com/t/9GEatFt6x9eu
Also select the default page template in the page attributes settings
– https://www.screencast.com/t/yzCLgg5F6TH
If this is not what you wanted, please provide more details about what exactly you want to do.
Thank you,
I have disable in option theme:https://www.screencast.com/t/nQWzAndriqIy
Topic to close.
best regards
