The post title in blocks can only be changed with custom css. Our theme has no option to change the post title colors on blocks. For that you will have to use this css:
.td-main-content-wrap .td_block_wrap h3>a{
color:red;
Or you can make the code more specific for each type of block. The code above changes the title colors for all blocks at once.
As for the post content color, you can change it from the theme panel:
https://www.screencast.com/t/fXf85nw5
