Hello. my website http://www.247cliq.com is having block problem. Please visit the website to see how the blocks is disarranged and moves to one side or view this picture http://247cliq.com/wp-content/uploads/2017/08/Blog.jpg I need a solution fast. Thanks
Hello humphreyjr,
I have inspected your website and I did not saw any problems with your Theme’s layout. Everything seems to work as expected, without any problems. Try to clear all the caches, purge all CDN files if you are using something like this and check the results.
The blocks is still not working well. Block 1, 14, 15 is the issue. Please recheck the website again to see if its OK from your end because it is not from my end. And secondly my my Multiple categories filter don’t minus category by (eg: -2345). I will be waiting for a permanent solution to this. The website name is http://www.247cliq.com. Thanks
This is block 1 -> https://www.screencast.com/t/PWfovbYS and it seems to work as expected. Where is the problem? Please provide some useful screenshots where you should show me your problem.
Thanks for the help. Maybe it’s from my browser. I will retry to check somewhere else. Thanks
