I didn’t install the social counter plugin as now I don’t need it. So I have also removed [td_block_social_counter custom_title="STAY CONNECTED" facebook="tagDiv" twitter="envato" youtube="envato"]this short code. after I done that, the padding between adblock and td_block was also gone. how can I fix it?
the gap are gone pic.twitter.com/JT0JwBq3Ag
— Jerry Ding (@ArchangelKiller) October 14, 2015
Hello jerryd,
I’m guessing you are editing a page in visual composer. Please check if you did not remove other parts of the code as well. If this is not the case, sometimes the visual composer row gets messed up and needs to be replaced. Simply delete the row that contained the social counter and recreate it using the 2/3 + 1/3 layout.
