Hello ABilgen,
Please notice that you can use the shortcode which is generated for each block in Visual Composer and place it everywhere you want in your post article, like this -> http://screencast.com/t/CXZ9zth19 -> http://screencast.com/t/FY2TdUKaL -> http://screencast.com/t/GyDsxUzKTP and the result -> http://screencast.com/t/Of3qsGGCcPR
Hope this helps!
Hi Catalin,
Thanks for your reply. We are already using that feature at the bottom of our posts but we need that right in the middle. Sometimes we write pretty long articles and give readers a chance to jump to another article before they got bored and quit before they reach the bottom.
So is there a way to put a tag-related article link in the middle of the post?
Have you tried this – it works with the theme and it’s awesome – and if you want it to look prettier get PRO
Pat
Here is how we use it – you can select how many words before it’s triggered, and how many times it appears (max 3 as seen here) and whether it will tag one on the end if it’s a short post – can’t run on tags/cats – but we just designate posts must be one day old (more can embarrass a news site!) PRO gives all sorts of style options, with live preview – doesn’t slow site
