How can i move review box
Hello
How can i move the review box in the top of the sidebar?
Refer screenshot
http://oi60.tinypic.com/2612c6t.jpg
Edit the post template you use and add this line: get_review();?> like this: http://screencast.com/t/9b41IZ6M
You will have to do this for each sidebar position and for each post template you want to use and set the reviews like this.
Thanks man
ummmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmaaaaaaaaaaaaa……..
Do you have any idea to add user rating along with existing review box. now a days, most of the themes comes with user rating along with admin rating to make it sense.
Any hacks?
The theme doesn’t have such a feature please use this plugin: https://wordpress.org/plugins/rating-widget/
I have seen it at other theme users and should work fine.
