Hi All,
I have recently purchased the Newspaper 9 theme and am in the process of positioning adsense ads on my website. In the Ads section of the theme panel there is only one option to place an inline ad (Article Inline Ad).
I currently use that ad option to place an ad after the first paragraph on every blog post. I also want to place another ad in the middle but all the remaining options including the Custom Ads option does not allow me to set the exact location I want the add to show up (e.g after the 6th paragraph).
Is there any way I can add another in article ad option so that it saves me from having to manually insert a shortcode to each post?
Your help is appreciated. Many thanks.
Ihsan
We are planning to increase the number of inline ads that can be displayed in the post content but for the moment only one inline ad can be set.
Here is a possible solution until we can implement more ads into our theme:
