How can i remove side place(?)?
Hi here is my website Photo: https://ibb.co/3SLvQVv
Hello, I cannot access the region that I have set in red square with “tagdiv composer”. I can’t delete and replace columns or anything there. How can I gain access?
Also i would like to add one more questions. When i want change mobile version of website. Nothing changes even though if i click many times to save button.
Please edit the page normally and change the setting for the page into Template: Default template because I think you have there the setting: Pagebuilder + Latest articles + Pagination and these are not editable by tagDiv Composer plugin.
Also, please check this topic where I explained each mobile version -> https://forum.tagdiv.com/topic/mobile-version-not-working-properly-2/ and choose what mobile version you want.
Hope this help you!
Hi Anamaria I couldn’t find “Homepage latest articles” How can i access that area?
There is no page settings.
Hello @drzac!
If you mean these settings: https://www.screencast.com/t/csuKV6Ccn9 then this will appear when you edit normally the page and scroll down to the settings. Please make sure you enabled all the panels from Settings -> Preferences and you do not use extra non-tested plugins.
