How change top menu color?
Hi friends
How change this color?
top
And this text
text
and
text
Hello Andre,
You should use the following code if you want to change the color for desired elements. Place the code in Theme panel->Custom CSS area.
The code is ->
.td-header-sp-top-menu .top-header-menu>li>a{
color:red!important;
.td-header-sp-top-menu .top-header-menu>li>a:hover{
color:green!important
.mfp-content .td-login-panel-title, .mfp-content .td-login-info-text a, .mfp-content .td-login-button {
color: red!important;
Using this code, you can change the values as you wish.
Hope this helps!
