How delete in posts element related
Hi I can’t find one element in posts: https://drukowanka.pl/kolorowanka/zhu-zhu-pets-w-samochodzie/ How remove tab: ,,więcej od autora” – https://ibb.co/hR2Zgdj
One more question about advertisment
I can’t find the file where I can add the ad code advertisment in post. Now I have advertisment in post – https://drukowanka.pl/kolorowanka/zhu-zhu-pets-w-samochodzie/ I have code below the text . I can’t add over the text 🙁 In attachment I send more info . Is possible option 1 or 2 add ? – https://ibb.co/C2MG0F2
I know is option Newspaper -> Theme panel -> Ads but it not working.
Have a nice day
Mat
I recommend you to use a Single Post Template from tagdiv Cloud Library, and you can design it with tagdiv Composer.
To display the related articles or more from author, you can use Flex Block and filter it https://www.screencast.com/t/SEmxo13Fo2X -> https://i.imgur.com/YIg3nPP.png
You can set the ads in Single Post Template from tagDiv Cloud Library and you can set top ad, 3 inline ads set after x paragraphs and bottom ad, please check this article -> https://forum.tagdiv.com/article-ads/ and video https://www.youtube.com/watch?v=biTpVVlr8j8
Ok but you told me all about tagDiv Cloud Library I can’t change posts to Single Post Template from tagDiv Cloud Library is not possible.
Ok is possible change all 15 000 posts to Single Post Template from tagDiv Cloud Library ?
I must create one single template ? and how on click change this template to all 15 000 posts ?
Have a nice day
Best Regards
Mat
Active global like this- https://ibb.co/pPdhK1T ?
Ok it’s working 🙂 Thx for this info about Single Post Template from tagDiv Cloud Library
Thx very much !!!
Have a nice day
I’m glad it is working!
Have a nice day, too!
