Hi team,
I like your theme, thanks for making a nice, customizable website. But I can’t seem to be able to make the header & footer display properly. I would like to have the green color extend all the way to the left and right, but as you can see from these images it stops:
http://www.tiikoni.com/tis/view/?id=23a215c
http://www.tiikoni.com/tis/view/?id=a579343
Secondly, there seems to be some duplication of the twitter option at the bottom of each post. How can I remove the twitter button on the right of the below image?
http://www.tiikoni.com/tis/view/?id=ae030c4
The plugins I have installed and active are:
Akismet
Coming Soon Page & Maintenance Mode by SeedProd
Contact Form 7
Disqus Comment System
MailChimp for WordPress
Quiz And Survey Master
tagDiv Mobile Theme
tagDiv Social Counter
WP Super Cache
WPBakery Visual Composer
Yoast SEO
Thanks and regards,
Paul B
Hello paulbar,
Thank you for reaching us! So, please notice that the layout of the theme can be used in 2 ways -> in full width and in boxed mode. Please keep in mind that if you are using a background image or color from your panel, the layout of the theme will be automatically switched to the boxed mode and that’s why the header and footer section is not in full width. If you want to get rid of it this behaviour you should check your settings and remove your background, like this -> http://screencast.com/t/ABlZZXMc or from there -> http://screencast.com/t/Tuz0tMqf
For your second request, if you want to get rid of it the Twitter sharing buttons, please notice that you should edit the td_module_single.php core file and remove some codes from there, like this -> http://screencast.com/t/kA7jXVA7o
