How do I locate "Befor closing of body tag" /body> in Newsmag?
I need to embed a player from my radio stream and I need to insert a code in the body tag. before the /Body> and I seem not to find it. Can I get a screenshot or instructions on how to find it?
Look in either the header.php or footer.php files.
Took a look at those but couldn’t find the closing tag ( /body> )
Closing </body> will generally be at end of the footer.php file.
e.g.,
<?php wp_footer(); ?>
</body>
</html>
REF – BASIC HTML INFO:
Definition and Usage
The <body> tag defines the document’s body.
The <body> element contains all the contents of an HTML document, such as text, hyperlinks, images, tables, lists, etc.
Example
A simple HTML document, with the minimum of required tags:
<html>
<head>
<title>Title of the document</title>
</head>
<body>
The content of the document......
</body>
</html>
  • This reply was modified 10 years by simchris.
Thank @Chris for your helps!
@oldswat
</body> can be found in footer.php file here: http://screencast.com/t/5hdFAMzTP
  • This reply was modified 10 years by Andrei L..
Thanks a lot. but unfortunately, its not working. Its a radio stream widget i generated from Centova Stream. One code needs to go in the body tag and the other on the page i want the player to appear. But it seems not to work and I might give up. Thanks for your help and if you have extra tips, please let me know.
You can edit the file which generate the post/page template used and place your code there: http://screencast.com/t/7UjT8J1ily
