I got this plugin, Worth the Read, which calculates reading time of the post.
I can use a shortcode, [wtr-time].
I’m using a child theme. How do I put this shortcode in the post headers, next to author name, number of views, comments, etc.
thanks!
Hello crazyheart,
First of all, please notice that plugin has not been tested with our theme and also, we cannot say for sure if it will work or not with the theme, sorry! You should edit the post templates if you want to change that section. For example, if you are using the post template style 1, you should edit the loop-single-1.php from here -> https://www.screencast.com/t/TzVyAEpZcp
