How do I see what posts are using which templates?
Hello! I have a lot of post templates over the years and I’m trying to figure out what posts are using which template. How do I go about figuring this out?
Access the article and check here near the green button: https://app.screencast.com/FBTsL7mtqEBcU
Also, you can see the template used when you edit the post with Gutenberg at the bottom of the page in the post settings.
Check also in the theme panel settings -> Categories -> Per category settings.
Sorry — yes, I understand how to view at an individual level. However, I have 60,000+ articles and I need to see it via a bulk process.
Is there a way to do that via export plugin and/or within the all posts screen, or somewhere else through custom code?
Our custom work team can help you with that. You can contact them here: https://tagdiv.com/premium-customization-services/.
